Bruces S-19 Build Log
Date:  8-16-2012
Number of Hours:  20.00
Brief Description:  Designed Dynon ADAHARS support bracket for wing
Perhaps the easiest place to put the Dynon ADAHARS sensor is in the fuselage behind the bagagge compartment, but when I measured the magnetic effect using a compass, with and without my steel frame bike inplace, I found that the most benign location is in the wing inboard of the fuel tank. I made up a paper mock-up of the support bracket and checked for accessability.
I will design the support so that it can carry two ADAHARS sensors piggy backed on top of each other.
Mockup of ADAHARS sensor and support bracket
Check for ability to replace
