Bruces S-19 Build Log
S-19 Venterra
Started the Right Hand Wing
Started building up the right hand wing
Spars on the work bench
The upper spar cap run-out has a sharp flange which will need to be blended out
The ribs prior to strighting with flutting pliers
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
