Bruces S-19 Build Log
S-19 Venterra
Fixed leaky fuel cap
Sanding the leaky cap filler neck smooth didn't fix the leak, so it cut a cork gasket obtained from NAPA auto parts and put it undet the cap gasket. it is captured under the black cap gasket so it will not come out. Works great.
No leaks
Blowing bubbles, a slight leak
Cut a cork gasket for the cap
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
