Works like a charm, the ring is held by the rods while the sender float is inserted in the tank with the ruber gasket and the screws are then threaded into there holes. I did not use any sealant on the gasket or screws. I replaced the screws and lock-washers that came with the sender with screws drilled for safty wire.
