Brief Description: Drilled Lower Leading Edge Skin
Drilled leading edge skins # 40 through the front spar and ribs. Then started drillling full size. Its a little hard to center the hole centerlines marked with a sharpie in the pilot drilled LE skin. Next time I will mark the center lines with a thicker marker.
