Bruces S-19 Build Log
Date:  9-24-2011
Number of Hours:  4.00
Brief Description:  Drilled Lower Leading Edge Skin
Drilled leading edge skins # 40 through the front spar and ribs. Then started drillling full size. Its a little hard to center the hole centerlines marked with a sharpie in the pilot drilled LE skin. Next time I will mark the center lines with a thicker marker.
LE lower skin drilled undersized
