Brief Description: Modified and match drilled aileron hinge doublers
The edge margin to the edge of the lightning hole at the inbd end of the inbd aileron hinge doubler is too short so I modified the doubler by triming off the inbd end and the pilot hole. Moved the new rivet location toward the spar flange. Looks good. Pilot drilled thru both doublers to #30
