Bruces S-19 Build Log
S-19 Venterra
Main Landing Gear legs
Filed as required the landing gear attach points and installed the legs in the with bolts in the very tight holes. Then installed the axial's and brakes. Mounted the tires on the wheel rims.
Main gear leg installed
axel and brake installed
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
