Bruces S-19 Build Log
Date:  11-11-2010
Number of Hours:  4.00
Brief Description:  Formed and routed brake lines
Used a hot air gun to form and then routed the brake lines between the firewall brake resevour and parking brake valve. Used Locktite 567 on the threads of the brake line fittings into the master cylinders, but will leave the tube fittins loose for now in case the need to be disconected later.
Fabricated bracket to hold Tee
Brake routing at pilots pedels
