Brief Description: preparing the center fuselage for joining
Spent a few after work days finishing some odd jobs prior to starting the fuselage join. I decided to not do anything about the rivet hole thur the rib into the bulkhead flange that falls on the edge of the flange. There will be a gap between parts under the rivet and a notch in the flange, but I don't think it will be a problem. Reamed the bolts thru the landing gear block.
Form block for bending a radius in baggage bulkhead flange
This hole c/t the baggage bulkhead falls on the edge of the flange
