Mounted Vertical Stabiliser. I had drilled the rear spar mount holes full size when I built the stabiliser so I had to be careful matching the holes to the 1/8 inch pilot holes in the rear bulkhead. Verified the angle of the stabiliser ( it was within +/-0.2 degrees of vertical) and drilled the upper close out to loack it in.
