Bruces S-19 Build Log
Date:  7-3-2010
Number of Hours:  8.00
Brief Description:  Mounted vertical stabilizer
Mounted Vertical Stabiliser. I had drilled the rear spar mount holes full size when I built the stabiliser so I had to be careful matching the holes to the 1/8 inch pilot holes in the rear bulkhead. Verified the angle of the stabiliser ( it was within +/-0.2 degrees of vertical) and drilled the upper close out to loack it in.
aft fuselage coming together
R.S. c/t bulkhead 5
R.S. c/t bulkhead 5
F.S. c/t bulkhead 4
F.S. c/t bulkhead 4
