Bruces S-19 Build Log
Date:  5-14-2010
Brief Description:  Discovered shipping damage to tailcone skins
On unwrapping the tail cone side skins I discovered that the fwd upper tab outs were bent to approximately 60 degrees. I consulted with ED Schwab at Ran's. He recommended straightening the skins, This area is under the center skin splice and will not be visible. I straightened the skins using some c-clamps as a press, worked great. - Build on.
