Bruces S-19 Build Log
Date:  5-5-2010
Brief Description:  Bent RHS Fwd Side Skin
Bent the right hand fwd side skin. I used 3 aluminum L angles, one clamping the skin to the bench and two sandwiching the skins. The vertical legs of the angles were orientated facing each other so that the clamps could be applied directly to the angle leg with out using a thick shim.
Side skin bent
Side skin bent
Angle orientation
Angle orientation
Fitup is good
Fitup is good
