Fabricated the rudder pedal bolt retainer bushings and match drilled the bolts and bushings for cotter pins. Started to put together the rudder cable pulleys but found that the kit is missing the 1/4" tube stock needed for the bushings. The inventory sheet does not have this listed even though it is in the plans. Minor problem, I'll e-mail Rans. Pulled the fwd fuselage side skins.
