Started contruction on the new tank design and did some practice welding. Switched to .050 3003 alloy for the tanks. Lot's easier to weld. Sweet! Practiced an eadge weld as well as a fitting weld. Found out the the fitting weld is easiest by just seam welding the skin to the fitting (basically a circular butt weld).
