Andrews Web Site
CH601XL - - Built from Plans
Rear spar assembly
Double checked rib stations on rear spar, center punched holes and drilled. Then lined up rear ribs on rear spar ribs stations, drilled and clecoed.
Clecoed wing skeleton. Reb stick is a yard stick. Added perspective to the picture.
Same picture with yadstick down other end. Pretty wide angle shot. WIng is larger than it looks in pix
Wing from somewhat above and on the right ooutboard side.
CH601XL - - Built from Plans Home
590
Fuel Tanks
Total Expense
Total Hours
354
