Fit rear ribs to main spar. Had to joggle ribs to get them to fit inside of spar cpa angles.
Everything fine up til rear rib 8# then split the rib while using joggle tool. Had to stop and remake rear rib #8, hour and a half. Check other joggles, some are a little tight looking but nothing bad. RR#8 got outright sheared in the joggle tool. Sure to be more careful in the future.
Swung the assembly around on the table and fit the rear channel to the ribs. Looks like something now! Looks like, well, it looks like a damn airplane wing. Pretty cool!
Fabricated rear channel root doubler and flap doubler and called it a night.
Right wing skeleton
Wing skeleton from outboard (right) side.
Another joggle. NOT the one I sheared. Little tighter radius than I like but OK.
