Cleaned up garage after last session. Riveted center spar. Neighbor Craig helped me hold setup up to bucking bar. Bar slipped a bit occasionally and caused riveter to make c-moon cuts on rivets heads. These will need to be removed and reset. Test fitted to halves to form full center spar assembly. Forgot to leave 4 rivet holes open for angles that fit top to bottom across center spar. Made angles, laid out rivet pattern and clecoed to center spar assembly.
Went to Home Depot and picked up more wall hanger brackets to store center spar safely on wall above worktable.
Cut out early and headed over Tara's parents for dinner.
