Cleaned garage good. Sh!thouse after last couple of jobs. Made better wall storage for stock sheet aluminum. Edges were sitting on floor. Hadn't seen any problems before but noticed a slight amount of light corrosion on one sheet that easily cleaned off with light rubbing with Scotch Brite pad. Made a few wooden cradles that fastened to wall a few inches off the floor. Also noticed mouse debris down around sheets too. Don't want any corrosion from mouse pee either. Saw what happened with outboard motor that was out in shed. A mouse had built a nest in there and there was a pretty substantial amount of corrision around the exhaust housing from the mouse pees. Had it been as thin as .032 sheet is would have been totally corroded through.
