Andrews Web Site
Date:  12-10-2006
Number of Hours:  6.00
Brief Description:  Joggle tool and rib supports
Started making joggle tool for the doing joggles in the front ends of the rear ribs. Rather than describe it, just check the picture. I made joggles in the stabilizer spars by routering the top corner of the work table and then clamping the spar to the table top and edge. Being the the rib is not straight as well as being much shorter and having flanges top and bottom that was not an option so some sort of joggle tool was in order.
Later I started making and installing standard Ls for rib 1 – 4 for the reinforcement for the wingwalk.
