Drilled common holes, took assembly apart and deburred all the holes. Dimpled all the holes on the skin, except the two on the leading edge in the middle I couldnt get everything lined up.
Came back a few hours later and attempted to dimple the leading edge middle hole and managed to tweak the skin while doing it causing the hole to oblong, and the dimple to not be flush with the skin but rather at an angle Had to order a new skin. Work will resume when new skin arrives.
