Brief Description: Finished drilling last few holes in rear spar
After drilling the last few holes in the left rear spar I cut up some 1/2 inch angle for the rib attach angles. Then cleaned them up with the scotch brite wheel and drilled them on the side that they will fasten to the ribs.
