Dons Web Site
Date:  3-14-2009
Number of Hours:  6.00
Brief Description:  More drilling on the rear spars
Today I match drilled the spacer bars between the cap strips on the right spar with the #30 bit. Then I drilled the little 1/8 inch spaceres that fill in between the attach plates along with the attach plates and webbs. Then I set the right spar aside and went to work on the left spar to get it caught up with the right. I laid it out on the table and this time I drilled the splice plate to the webbs first. Then drilled the spacers between the caps to the web. Then I started drilling out the caps and webbs with a #30 bit.
