ARTHUR'S WEB SITE
Date:  2-11-2010
Number of Hours:  1.50
Brief Description:  Canopy
When I started drilling the holes along the rear bow of the Canopy Frame, I was using a pneumatic drill with a 1/8" plexiglass bit. The awkward position coupled with the weight of the air hose caused the bit to slip while positioning for drilling. This left two scratches 3/4" and 2" long which started at the hole and progressed toward another edge. Before proceeding I decided to remove the scratches or risk cracks. I purchased a "Scratch Out" kit from Van's. It was determined from the instructions in the kit that I had deep scratches as you could feel them with a finger nail.
I started with 600 grit wet/dry sandpaper and warm soapy water, then proceeded with the materials in the kit. Once the scratches were removed with the sand paper the rest was easy, but somewhat messy.
Van's Scratch out Kit
