ARTHUR'S WEB SITE
Date:  12-19-2009
Number of Hours:  1.50
Brief Description:  Fuel Tank
Pg. 37-07
Step 1: Temporarily attached the Fuel Neck to the Fuel Tank Assy. Installed the Fuel Cap and sealed with duct tape. Attached the air valve to the AN832-4D using hose clamps and rubber hose supplied. Attached a quality party balloon to the Fuel Strainer with electrical tape. Inflated the balloon by pressurizing the tank through the air valve with a bicycle pump.
Step 2: Sprayed soapy water on all connections, screws, rivets and seams. Found 4 leaks. Two were on the test equipment. The balloon leaked at it's connection. Secured using a small hose clamp. Air valve leaked at it's connection. Secured with a smaller hose clamp. Two screws on the Fuel Sending Unit leaked. Secured by tightening. Retested and after 24 hours there were no leaks. The balloon retained it's original circumfrence.
Testing Fuel Tank
Testing Fuel Tank
