ARTHUR'S WEB SITE
Date:  10-7-2009
Number of Hours:  6.00
Brief Description:  Fwd Upper Firewall
Pg. 29-04
Step 8: Clecoed the Panel Base to the Firewall Upper. The Panel Base did not abut the Canopy Deck. Had to remove 1/16 from end of Canopy Deck. Match-drilled and deburred #30 the holes in the Panel Base and Longerons.
Step 9: Clecoed the Canopy Ribs and Panel Base, then Match-drilled #30 and deburred the holes between the Panel Base and the Strut Attach Angles.
Pg. 29-05
Step 6: Curved the forward edge of the Upper Fwd Fuselage Skin.
Step 7: Dimpled the holes in the Upper Fwd Fuselage Skin.
Dimpled Holes
Dimpled Holes
