Pg. 14-2 Step 10: Riveted the Flaperon Hinge Brackets to the Hinge Plates in a ramdom pattern. Took caution with the flush rivets, not squeezing the rivets completely to avoid binding the bearings. Step 11: Separated the Tip Attach Angle and Identified. Pg. 14-3 Step 1: Clecoed the Hinge Assys. to the Rear Spar Doubler Plates. Step 2: Riveted the inboard flange of the Hinge Assys. to the Doubler Plates. Step 3: Clecoed the Doubler Assys. to the inboard end of the Rear Spar Web.
