Cleaned up F-1205A, Mid-Fuse Brace. Touched the paint with gray primer. Pg. 33-04 Step 1: Test fit the F-12119B Anti-abrasion Strip to the Mid-Fuse Brace. With an ultra-fine felt tip marker and a straight edge, marked a line on the top surface, 3/4" forward of the aft edge. Step 2: Installed the Anti-abrasion Strip to the Mid-Fuse Brace by removing the paper backing and applied it along the traced line and pressed into place.
