Pg. 32-05 Step 6: Attached the outboard ends of the Control Stick Pushrod Assemblies to the Control Sticks. Step 7: Attached the inboard ends of the Control Stick Pushrod Assemblies to the Flaperon Mixer Bellcranks. Pg. 32-06 Step 2: Passed the two Flaperon Pushrod Assemblies through the holes in the Center Section and F-1206A Bulkheads. Step 3: Bolted the forward end of the Flaperon Pushrod Assemblies to the Flaperon Mixer Bellcranks. Step 4: Bolted the WD-1215-L&R Flaperon Torque Arms to the Bearing Brackets. Step 5: Attached the aft end of the Flaperon Pushrod Assemblies to the Flaperon Torque Arms. Deburred (4) F-1258 Rudder Cable Links.
