Pg. 32-07 Step 6: Separated and deburred F-1266C Flap Detent Bracket Angles and F-1266AD Flap Detent Bracket/Stop. Step 7: Attached Flap Detent Bracket Angles to the Flap Detent Bracket. Step 8: Clecoed the the Flap Detent Angles to the F-1266B Flap Detent Bracket Plate. Step 9: Match-drilled #30 the holes from the Flap Detent Bracket Plate into the Flap Detent Angle without holes. Step 10: Machine countersunk the holes in the bottom side of the Flap Detent Bracket Plate. Pg. 32-08 Step 6: Cut the F-1261 Spacer into four parts. Step 7: Positioned the Spacers, the Match-drilled #30 the holes from the Torque Tubes into the Spacers. Step 8: Final-drilled #12 the holes in the Spacers material.
