Pg. 37-03 Step 1: Riveted the Fwd Baffle and T-1208 Baffle to the Main Tank Skin and together. Verified the fuel passages were open and the outbd passage and tool holes were sealed. Step 2: Riveted the Fwd Baffle to the Fwd Bulkhead. Step 3: Adjusted the joggle of the Aft Tank Bulkhead top flange. Step 4: Riveted the Aft Tank Bulkhead to the Main Tank Skin. Step 5: Applied sealant to the inside bottom corners. Step 6: Riveted the Attach Angle to the Aft Tank Bulkhead.
