Pg. 29-04 Step 8: Clecoed the Panel Base to the Firewall Upper. The Panel Base did not abut the Canopy Deck. Had to remove 1/16 from end of Canopy Deck. Match-drilled and deburred #30 the holes in the Panel Base and Longerons. Step 9: Clecoed the Canopy Ribs and Panel Base, then Match-drilled #30 and deburred the holes between the Panel Base and the Strut Attach Angles. Pg. 29-05 Step 6: Curved the forward edge of the Upper Fwd Fuselage Skin. Step 7: Dimpled the holes in the Upper Fwd Fuselage Skin.
