Section 29 Primed OD of F-1201H Pg. 29-02 Step 7: Dimpled and riveted the nutplates to the Antenna Shelf. Step 8: Riveted the Antenna Shelf to the Firewall Upper. Step 9: Dimpled the rivet holes in the bottom flange of the Firewall Upper. Pg. 29-04 Step 1: Separated and Deburred the F-1201Q Battery Mount Angle. Step 3: Separated F-1202D-L&R Panel Attach Strips
