Step 1: Bolted Clevis Plates together. Step 2: Match-drilled the holes from the Clevis Plate into the Push Rod and Deburred. Step 3: Clamped the Threaded Insert onto the end of the Push Rod. Step 4: Match-drilled the holes through the Push Rod. Step 5: Riveted the Clevis Plates and the Threaded Insert to the Push Rod. Step 6: Installed the Rod End Bearing into the end of the Treaded Insert. Step 7: Attached the Rod End Clevis to the Servo and adjusted. secured with jam nut. Will do servo testing later.
