ARTHUR'S WEB SITE
RV-12
Landing Gear & Engine Mount
Pg. 35-04
Step 4: Attached the L & R Main Brake Lines to the fittings in the in the Inboard Main Gear Attach Brackets.
Pg. 35-05
Step 1: Attached the L & R Main Brake Lines to the F-1204D Center Section Aft Bulkhead with wire ties.
Main Brake Lines Attached to the Gear Attach Brackets
Brake Lines attached to Each Other & to the Center Section Aft Bulkhead
RV-12 Home
2008
Fuel Tank
1165
Miscellanea
Service Bulletin
