Put torque seal on the torqued nuts and bolts. Pg. 32-13 Step 2: Installed the .197 X .313 X .968 bushing between the F-1250 L&R Pulley Brackets. Step 3: Secured the Forward Stabilator Cables to the Control Column. Tightened to allow the cables to swivel within the horns on the Control Column Step 4: Routed the aft end of both Forward Stabilator Cables over the bushing and through the hole in the Aft Intercostal. Step 5: Installed the two pulleys assuring the cables were between the bushing and the pulleys.
