Pg. 12-10 Step 12: Repeated steps 8through 10 with the Trim/Servo Assy fully extended.
Pg. 12-11 Step 1: Reinstalled the Tailcone with the screws. Step 2: Checked for 1/8" clearance of the Rudder, Stabilator and Trim/Servo Assy to the Upper and Lower Tailcone Fairings. The leading edge of the Stab will be trimmed to get 1/8" clearance when it is next removed.
Removed the masking from painting the trim areas.
Final painted the Roll Bar Brace and Rt. Support Frame.
