Had 5 hole that became misaligned on the forward edge of the Tail Cone Fairing. Filled them with flox and redrilled them. Pg. 12-09 Step 7: Final-Drilled with a #27 plexiglass drill the holes between the Tail Cone Fairing and the Tail Cone Assy and clecoed. Removed the Tail Cone Fairing, deburred the holes, cleared the chips and reclecoed. Step 8: Checked the clearance between the Tail Cone Fairing and the Stab Spar Box. Marked areas needing material removed for the Spar Box and the Rudder Horn. Removed the Tail Cone Fairing.
