Pg. 34-14 Step 1: Used along commercial sanding block with 80 grit sand paper to form the foam blocks to the contour of the Fuse. Step 2: Taped the templates onto the Canopy and Fuse. Step 3: Placed a strip of electrical tape along the edge of the templates. Bridged the gap between the tempates by maintaining a constant distance from the aft edge of the Upper Fuse Skin. Removed the templates and placed a second layer of tape on top of the first. Masked off the Canopy aft of the electrical tape.
