Pg. 38-03 Step 8: Beveled the eyelets of the F-1201J and K Upper Cowl Hinges. Pg. 38-04 Step 1: Modified the hinge halves for the F-12116-L&R Mid Cowl Hinges. Marked the hole locations on the hinge halves per the plans. Step 2: Layed out the hole patterns for the F-12115 Side Hinges, F-1201J&K Top Cowl Hinges and F-12117 Lower Cowl Hinges. Holes will be drilled later when cowl installed.
