After applying the white labels, everything seamed to go down the drain. We were only successful with 50% of our attempts going forward. A couple of attempts were messed up for not following the correct sequence ... like pealing the mylar sheet instead of letting the labels transfer in the water bath... and or applying the spray adhesive on the wrong side... and some other bad attemps that are still a mystery. I guess there is still a lot more learning to be done.
