Brief Description: Painting the sub panels - again
Well... as it turns out.. Once I had painted the sub panels I realized that the top coat was applied to the wrong side. so I had essentially 3 sub panels with only a coat of primer which was a darker gray compared to the light gray I used on the rest the panels. As it turned out, I liked the way it looked.. so I went to the paint store and asked them if they could re-tint the left over paint (which I had lots) to match the darker gray color of the primer. I then applied 2 top coats of this darker gray to the correct side of each sub panel. I think this is going to come out great !
