Brief Description: Setup working table for Center Spar Drilling
Based on fellow builder Debo Cox fine buidling skills... I cut a hole though the table so as to install the drill press at the right height for drilling the holes on the wing spars. It will be important to drill perfect holes (at 90 degrees to the spar caps).
