Brief Description: 2.- Finilized all cotter pins and safety wire
Drilled a hole through the front axle and installed the cotter pin. Also drilled holes on the main gear attachment bolts so as to install the cotter pins. Also finilized all safety wire. After 2 years, 8 months and 9 days... N115AR is ready for inspection. Next step is to submit paprework to local FSDO.
