Brief Description: 1.- Final Installation of the wings
After many hours of in and out... in and out... finally got to the point of installing the wings. Since the rear channel bolt holes were already drilled, the only thing left to do this morning was to tri, the skin to make room for the wing rubber seal. Also Installed the control cables at the bell-crank end and ran the cables through the fuselage... so as to install later.
