Brief Description: 2.- Finished connecting the CHT senders
Finished connecting the CHT senders and the Carb Heat Temp probe. Since the Bing carburator does not have a place to install the probe, I decided to install it on the clean side of the air box so as to be able to confirm the rise in temperature when applying carb heat. Also cleaned up the wiring of all the CHT and EGT senders.
