Brief Description: 2.- Finished the Oil Cooler Installation
This took longer that expected. Once Installed I realized I did not have enough clearance between the right fitting and aluminum base angle that is installed on the engine.... so I had to remove the oil cooler so as to remove about 5 mm of the inside corner of the base angle.
