Brief Description: Worked on installing the throttle mechanism
Today I decided to take a stab at the throttle mechanism. Before buying the engine I spoke with Pete at Jabiru USA and explained that I wanted to install a throttle quadrant. He actually suggested I use the same installation they have developed for the 701 FWF kit (dual trhottle). the only difference is that the push rod will be linked to the throttle quadrant instead of a knob. Also the hinge/levers are installed on the firewall (cabin side - on top of the firewall stiffener).
