Once again based on the lessons learned from the flaps, I first bent the 20mm flange then flipped the sheet around and then proceeded with the 73 degree corner. Everything is looking good so far. I then bent the trailing edge little over 90 degrees with the brake and the rest to be done by compressing 2 pieces of wood set along the trailing edge, with clamps.
